PDE..........Some of the Myths busted.
Quote:
Originally Posted by
RodRussell
I can only speak about cavaliers, so I know nothing about the other breeds discussed in PDE, but I can tell you that as far as the criticisms of PDE regarding cavaliers is concerned, roughly 90+% of that criticism is phony. Whether it is the falsehood about the dog being denied its meds, or whatever, the criticisms have been largely a combination of people spreading falsehoods about PDE and other people blindly falling for those falsehoods.
http://pedigreedogsexposed.blogspot....hs-busted.html
Pedigree dogs exposed "mark2" -should it be made
anniemac
That's a good idea
Sent from my Droid using Tapatalk
PEDIGREE DOGS EXPOSED "MARK 2" - SHOULD IT BE MADE
Anne,
Could I also suggest that you Contact the Researchers into CM/SM, about all the Questions you have about those Conditions Afflicting our Cavalier Breed.
No doubt they will give you a lot of Information.
Bet
Pedigree dogs exposed "mark 2"-should it be made
anniemac
Rod,
There are reasons that I will not get into on this board, that I would definately not want a PDE 3 in the usa. We can discuss of this board.
PEDIGREE DOGS EXPOSED "MARK 2" -SHOULD IT BE MADE
I am feeling very CRABBIT at the moment ,I am suffering from Sciatica.!!!!,but I feel I Really have to answer Anne about the The PDE TV Program
I cannot speak about the other Breeds of Dogs that were involved in the Program , but if it had not been for the Shock Way of dealing with the SM Problem in our Beloved Cavalier Breed ,no notice would ever have been taken or the Cavalier Buying Pubilc been made aware about the Suffering that SM causes to our Cavaliers
I will never forget the Screaming of the Cavalier in the Program, nor will I am sure many Lovers of the Cavalier Breed.So if the PDE Program has made the News-Papers ,etc aware of what a Cavalier is Suffering , then Thank You Jemima Harrison.
Softly ,Softly ,Cachee Monkey ,is absolutely no use in how the SM Problem is dealt with for Cavaliers.
We have now gained more information about the CM Problem in the Cavalier Breed, that about 90% Cavaliers have CM ,also 85 Whelps Researched for the Foetal Tissue Research , ALL HAD CM.
CM is Chacterised with the Brains being too Big for the Skulls ,hindering the Flow of Cerebro Spinal Fluid .this causes Syrinxes to Form then SM.
Anne ,if you don't believe me about this ,contact Dr C Rusbridge, Neurologist, where she has mentioned it on the Intrenet.
Also maybe you could read many of the Veterinary Papers on the Internet ,which have been Peer Reviewed about the CM/SM Problem in our Cavalier Breed where I am sure you will get all the Answers to your Questions.
Maybe even contact Jemima Harrison as well.
Bet
