apologies -- may have accidentally deleted some users
If you can log in then you are fine and are not affected. I was trying too fix a mail problem with PMs that has been ongoing since Aug 28th and also do a board upgrade and may have affected a couple of registrations in the process; apologies if that is the case. If you can't log in then you just need to reregister. This is probably only a couple of folks. If you see your name up where it says Log out at top right then you are unaffected.
icon_slapper
