Greenie bones???
Jen114
I remember hearing somethign about them ? that they were bad? is this right any information will be great
I give them all the time. Like many chews they can cause serious probems if the dog bites off a chunk and it causes a blockage of the gut. This is true of cornstarch bones, rawhides, soft toys, socks, rope toys... No treat or chew should ever be offered unsupervised and if your diog is a gulper, then Greenies are not a good choice. It is also important to only give the correct size, which is the petite size for cavaliers.
