Results 1 to 5 of 5
Thread: Harnesses
    Aug 2006
    Default Harnesses
    Hi just want to ask about the puppia and other harnesses. My dog trainer really frowns on them because they promote pulling. Have you found this? I worry about using a normal collar but also worry about teaching pulling on the lead. My sister has a tibby who pulled on the harness and was moved to a flat collar and now doesn't pull.
    What have you found with your harnesses and what do you think is the best option?
    Vanessa
    May 2006
    NY, NY
    I've found nothing worng wit the Puppia harness...It works really well. I mean King doesn't pull but usually won't unless he sees a person he wants to meet
    Aaron, King and the rest of family
    living in NY
    Feb 2006
    Santa Monica CA
    It's common for a dog to pull against the pressure of a leash attached to their back or the back of their neck, and as far as i know, they'll do it with either a collar or a leash. Zack sure did. He loved to pull.
    At first i was using a collar because i didn't know any better, about the vulnerability, and he pulled hard. Then i learned that this can potentially harm a small dog, and i got a harness that had the clip on the back, and he pulled as hard as ever, but i didn't worry as much because it wasn't choking his neck, although it still seemed like a lot of strain on his body as he would pull me along.
    Then i had him at a puppy class and another dog had an interesting looking harness on and i asked about it and it was an Easy Walk harness, designed to reduce or eliminate pulling because the clip is on the chest--it's not fun to pull when it's clipped to the chest, the way it's fun when clipped to the back. Pulling when it's attached to the chest tends to throw them off balance a little, and from the first day i put one on Zack, the hard pulling stopped, just like that. There were times when he would pull on it when excited by something, but he would never pull for long. Before i got that harness, he pulled constantly. Now, he rarely pulls and never has hard as he used to.
    He's gotten out of the habit of pulling now. I have a Puppia and he walks fine in that. He pulls a bit more in it, they love that feeling of pulling against something attached to the back of them, but he's not big on pulling anymore. He's trained to heel on command.
    Anyway, i've had a really good experience with the Easy Walk and will definitely recommend it to eliminate pulling.
    here's what it looks like
    click
    Here's zack on a retractable leash with the Easy Walk, you can see the leash isn't taut. It's a little slack, even though he's in a forward mode.
    Sep 2006
    wallington surrey (uk)
    Default harness
    ive just got a harness (puppia)and i think it is much betteron my male cav ive got a pink one for molly but i do notice when she pull it will make her cough as it pulls on her throat otherwise they work better for me than a normall collar and they are soft against there skin
    christine and cavaliers molly+charlie
    Sep 2006
    Belfast
    I like easy walk harnesses. Holly walks in them very nicely. There's only one problem- persuading her to walk! Once she gets out of 'I'm not going anywhere and you can't make me' mode, she walks beautifully. Her walking on the lead has also improved- she walked quite a way yesterday on the retractable (attached to collar) and the lead was slack most of the time. I've ordered a puppia- I think maybe the pressure on a different spot is freaking her a little, whereas on the puppia the weight will be more familiar. We'll see. It's a pretty one anyway- the pink 'orion' one, to match the blue ditto I've ordered for Chloe.
    Holly - 7years
    Amber- 3 years
