Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Car Safety
    Jul 2006
    Toronto, Ontario
    Default Car Safety
    I seem to have made a huge mistake and I need advice on how to fix it.
    When I first got Kosmo I let him sit on my lap in the car. Stupid, I know, but it has been this way since we've had him. He's grown accustomed to it. I've been planning to change him over to something more secure for a while now, but I seem to have hit a brick wall for the moment.
    I bought a car about 2 weeks ago. It's fun for me!, but Kosmo has to stay on his own in the car. I made a contraption for him so that he would be more secure when I drive alone. I first buckled the seat in, then put a blanket in the back seat, put his puppia harness on, and took his leash and twisted it and tied it around the seatbelt in such a way that there's no way he's going to get out of it. The leash is also short so if something happened, he wouldn't go flying. I also gave him a new toy so that he would lay down and not be trying to hop all over.
    The first time I drove with him alone was on Saturday. Except for his crying, he did fine on the way to class. On the way back.. well. . . I am driving.. I smelled something funny.. and then looked in the rear view to see him eating his vomit. I immediately pulled over to the side of the road and cleaned it up as best as I could. Thank God for leather seats.
    Tonight I took him out for the second time, and same thing, he puked all over. So, my question is, how do I fix it? Is he forever going to be carsick in a car? A very wonderful person is sending me a carseat.. ( THX) but I am worried even secured into the carseat unless I am physically holding him, he will puke. Do you guys think it would make a difference if I bought a crate for the car? And then how do I buckle the crate into the backseat so it's secure? A seatbelt harness is out of the question as that's what I made Kosmo's harness into and obviously that doesn't seem to work.
    I think it's important to note that dog safety in cars is EXTREMELY important. If Kos was sitting on my lap and something bad happened, I most likely would be without him. I can't even think about that.
    How do you all secure your dogs when you drive? And do any of you have dogs who are prone to car sickness? How do you fix it?
    Sara, mommy to Kosmo ~ 4 year blenheim boy and Faith 3 year b/t girl *rescue*
    Aug 2006
    Western Australia
    I use a harness and a doggy seat belt extension that clips into the normal seatbelt clip. I also use a hammock type thing that means there is no gap for the dog to fall down, even though they can not fall as they are clipped in they do have a bit of slack on the extension belt so they can move around to reposition themselves, one of my boys is very nervous about being in the car and this makes him a little calmer.
    Does your baby have a bit of loose and room to move around slighty so he can shift his balance and get comfy ?
    Not sure if you already do ?? but could you try him in the passenger seat in the front to get him used to it then move into the back eventually ?
    Good luck
    Luvzcavs xx
    Harry (tri) and Digby (blen).
    Jul 2006
    Toronto, Ontario
    luvzcavs,
    I didn't leave much slack at all for him because I was scared if I got rear ended he would have flown up and hit the passenger seat. (I am a HUGE worry wart.. it sux..) Also in the front I am also scared that if the airbag went off then it would hurt him really bad. I might check into things and see if my car has an option to turn off the passenger airbag. I know some of them do now adays.
    Do yours not get car sick even when roaming around in the hammock?
    Thanks for the reply.. this topic doesn't seem to be brought up much and I am COMPLETELY lost on it.
    Sep 2006
    New Jersey USA
    There is a carrier that I use:
    click here to see carrier
    It is both a carrier and a carseat (attaches to the seat via a seatbelt loop). They have different sizes. The small I have been borrowing from my sister and it works so well I am going to get a larger one for Lucky since it is getting a little small.
    It is also a good carrier because it has wheels (like a suitcase would) and saves your back.
    Good Luck
    Lani
    Mom to ruby Cavalier Sparky & red Lhasa Apso Caroline
    RIP my sweet angel dog Lucky
    I use the small softsided zipper crates from PetSmart. I figured out a way to put the seatbelt, fully extended, around it to hold it in place in the back seat. They have cozy crate pads inside, and the pups are comfortable.
    Cathy Moon
    Aug 2006
    Western Australia
    Very valid point about the air bag, my car does not have one in the passenger side so I did not think of it.
    With the slack I only leave enough for him to go from a sit to a lie down or maybe turn around if he wants to, it is something I worry about also as it could potentially cause a sling shot effect if rear ended but I figure its a risk I will take for his everyday comfort, but again a very valid point.
    No they don't get sick with the hammock, its as if the reassurance of not having the big hole to fall down (even though they can't fall) makes them less nervous and so they don't get sick ?
    Your boy could be getting a different sensation in his tummy from sitting on the seat oppose to your lap and it could be a mix of genuine car sickness mixed with a bit of nerves/anxiety ?
    Best wishes
    Luvzcavs xx
    Chicago Burbs
    i use a harness for the car, or his travel crate in the back seat. he doesn't seem to mind either. he used to try to bite the harness and when he was smaller he worked his way out of it and then ended up in my lap! my airbag will turn off if i have him in the front so i'm not worried about that, but it depends on where i'm going and how long i'll be in the car. sadly, if my boyfriend is driving, i will hold him in my lap in the front seat. i know i shouldn't do that. i'll have to get used to putting him in the back. i hope that helps a little and good luck!
    Lauren
    Brady's Mommy (D.O.B 4/25/2006)
    San Diego, California
    Both of mine sit in the backseat and have seatbelts that attach to their harnesses. We've never had a problem with carsick but I've heard about using ginger. Don't know the specifics though.
    Cathy
    Jul 2006
    Darwen, Lancashire, England
    My two travel in the "boot" of my car with the dog guard so they can't get forward and its well padded with cushions and duvets in case I ever got bumped. In Joel's car they both have harnesses on the back seat. Even Oakley fits in his harness at 9 weeks ( he does weigh 5 pounds - little fattie)
    Kirsty
    Merlin and Oakleys Mum (Merlin -Male/B&T/5 years, Oakley - Male/Ruby/3.5years)
    For a dog to be safe, you need to either use a specially designed dog seatbelt or other restraint designed for this purpose as some have noted above, or crate him and run the seatbelt through the top of the crate so it is secure. In an impact, loose dogs, even in a padded area in the back, could be propelled forward at up to 100mph if you are going say 50mph. Even if the dog travels *six inches* its neck could break and its skull be crushed!! So please -- secure your cavaliers with a correct restraining harness or in a crate. I used to think crates were safer; I have since read that a seatbelt on a seat with NO AIRBAGS may be the safest but on the other hand many rescue services would not save a dog in a harness but they will take one out in a crate.
    An airbag will decapitate or crush a small dog immediately so a dog CANNOT be on a seat that has airbags.
    A dog loose or on a lap is extremely dangerous to the occupants of the car, not just the dog. If you are hit by a dog flung through the car at even 20mph -- which would happen if you were creeping along at 10-20mph -- you could be killed on impact if it hit your head.
    The Whole Dog Journal just had an article on safe travel in cars.
    In an emergency when I've forgotten a proper belt I have run a seatbelt thru a Puppia but the design of a Puppia could throttle a dog in an impact. I've also used a lead attached to a harness then tied to the headrest or seatblet (clipped in) at a short enough length not to allow the dog to be flung forward but neither of these are very safe methods. Sometimes when I am moving a number of dogs though it is the best I can do at the time.
    I always carry a medium crate in the trunk/boot as well.
    Cavaliers: Jaspar Tansy : Mindy Connie Roxy Neasa
    In memory: Lucy Leo Lily Libby
