Shay said:
....Since we have been home with Lily, we put a collar on her an she began scratching around her neck. I thought she just didn't like the collar, but she is still scratching and has had it on for 3 days Not excessively, just intermediately. She has let out little whimpers, and her back legs seem to be clumsy. She seems to chew her back legs and lick her front paws. We brought her to the vet when we picked her up, and his only concern was that she was not akc registered, but cksusa registered.
Am I just being paranoid, and these are just normal puppy things? Could the signs of Syringomyelia begin showing at 8 weeks old? If she does have it, does it mean that it will be the sever type since it presented so young, and is it fatal? Any information will be greatly appreciated!
Shay and Lily
I am just learning about cavaliers in the past year and have just scratched the surface, and have so much to learn, but from what little i've learned, i would say at this age, even if the scratching, yelpking and incoordination are not normal, even if she has a problem, there are many things that could explain the symptoms other than SM. While SM can start at any age and is more severe if it starts early, the things you describe may be normal behavior or may be signs of any number of things. Obviously one thing that can cause frequent scratching, biting paws and legs, could be fleas, even fleas that aren't seen, it only takes one.
And skin allergies can cause scratching. Allergies in puppies and dogs can be caused by lots of things, environmental things in a new home, things in their food. Some pups have what may be reactions to vaccinations which have allergic kind of symptoms.
You did right, having her checked by a vet, and it sounds like there is no sign of anything abnormal.
About leaving the collar on, my daughter Lisa's breeder told her to leave the collar off except when going out for a walk, just because she said it would be better for the coat and fur, the look of it. In getting a puppy used to a collar, it does make sense to keep it on them.
I've never kept a collar on Zack except when we go out, and it's not a collar, it's a halter. I choose to avoid a collar to avoid any possible risk of aggravating any tendency toward SM, a disease that originates from a skull malformation that originates in the area where a collar pulls against the neck. I understand this is a fairly common practice among cavalier owners, to avoid using a collar in favor of using a halter, also because of small dog trachea injury risks.
Other than going for walks, i'm not sure what would be the purpose of having a collar on a dog, unless there's a risk of them escaping and they would need to be wearing their tags at all times.
When i first met Zack, at the home of the woman i got him from, he wasn't scratching but i did see a flea on his belly and mentioned it to her. It wasn't until another occasion that i brought him home. She said she uses Advantage on them and that he had recently had advantage. At first, i didn't notice a lot of scratching, but when i did see him scratch, i thought it was from those fleas i'd seen on him, although i was no longer seeing any.
Zack had bloody diarrhea the day i got him. He otherwise seemed fine, happy, playful, energetic. He was seen by a vet and said to be fine, and was given medication for the diarrhea which cleared up the next day completely. I'm not sure, because i didn't write it down, if he continued to scratch that week.
A week after he saw the vet, because the diarrhea had stopped and he seemed well, i took him to have the last of his puppy shots. Soon, the diarrhea returned, and he was scratching a lot. I was worried about SM because Advantage didn't help with the scratching and i wasn't seeing any fleas. He had one episode of suddenly starting to shriek in the middle of while he was scratching his neck, and while screeching, he got up and ran into the house. I was very worried and upset about that.
He continued to scratch a lot for the next 3 weeks and also started vomiting, and continued to be receiving medications for diarhhea, vomiting, colitis, with no improvement.
Finally he was treated for worms, although he had been previously dewormed, he had three negative stool samples, and no worms were seen by me in any stools or vomit, but immediately after the first dose of the worming medication, the vomiting stopped, the diarrhea cleared up permanently, and the frequent neck scratching stopped.
There was never anything seriously wrong with him--but he was sick for weeks because no one guessed at first what was wrong with him, and scratching was a major symptom which at the time was not taken seriously as anythig abnormal.
i hope your girl is just having normal things going on, and at the same time, i support your maternal instincts and your efforts to become informed about the possiblities. SM seems so unlikely, there's no reason to worry about it at this point because if she has any problem at all, it's likely to be any number of benign simple things.
