posting pictures help!!!
Yvonne117
Have been away for Easter and now back cannot work out how to post pictures. Have read advice and tried putting
Yep, what Veronica said... but also if you go into the control panel (User CP) and turn on full WYSIWYG editing as default, you will get a whole heap of icons with formatting & other tools. You can then just click on the picture icon, that looks like a little mountain with a sun in it, and a pop up box appears prompting you to insert the URL of your picture.
Veronica, many thanks now working.
Caraline, cannot seem to do it thru CP user. I dont have that option to change to full WYSIWYG editing as default (or maybe I am a bit thick!!) thanks for your help anyway.
You do have the option. It is in User CP/Edit Options/ Miscellaneous Options (almost at the very bottom).
