Results 1 to 10 of 18
Thread: does anyone
    Feb 2008
    Default does anyone
    on the board have two cavs of the same age?
    Illinois
    My two are close in age...only 7 months apart.
    Jato - Blenheim, Nov. 2007
    Zoey - Ruby, June 2008
    Nov 2005
    Chicago burbs
    Quote Originally Posted by nicola View Post
    I have littermates- Domi and Mia (dob 7/18/04), Teddy and Hunter (dob 11/20/04), Noel and Dickens (dob 12/21/05)
    Atlanta, GA
    I had littermates and a cousin who was just one week older than the littermates........but they came to me at different ages (one, two and four) so they were not always together from day one.
    Pat
    Pat B
    Atlanta, GA
    Aug 2006
    Dublin,Ireland
    I have Pippin just turned 5 yrs old and DJ who will be 5yrs in june, but DJ has only been with us a year.
    Gus(blenhiem) Pippin(tri) DJ(ruby)
    Two of mine are only one month apart in age. They've been together since they were 5 and 6 months old.
    Cathy Moon
    In case anyone is interested, I found an interesting thread about 'Littermate Syndrome'.
    http://www.flickr.com/groups/goldenr...7594564290493/
    We were forewarned by our trainer (Bless You Michelle!), so we did everything recommended to raise our puppies (India and Geordie) separately. It was a lot of extra work. They grew up to be individuals and bonded with us more than each other. But they are good friends and love to play together daily!
    Cathy Moon
    Nov 2005
    Chicago burbs
    Quote Originally Posted by Cathy Moon View Post
    I've never encountered this-- not even a little bit. Cavaliers just seem to "love" being with other cavaliers. Go to a club show, there are MANY cavaliers all over the place(sometimes 30 in a room). IF another breed of dog walks in, the noise is deafening. My pups are kept together until they are at least 10 weeks old (earliest I'd ever homed a pup). At 7 weeks, cavaliers aren't ready (let alone wanting) to move away from their pack. I prefer they stay together until they are 12 weeks old. Between 10 - 12 weeks, we then do individual crate training and beginning house training.
    Cathy thanks for that -- will add that to the links on this topic as well as the article from this UK trainer quoted on that thread:
    from Stan Rawlinson, dog trainer.
    Buying Siblings
    The Worst Of Both Worlds
    Buying Two Puppies
    The incidence of owners purchasing "Siblings", either same sex or brother and sister from the same litter or two puppies from different litters and breeds but of similar ages, is now more prevalent than at any other time in living memory. The old dogmen and owners knew the pitfalls and problems that this action would create. However this knowledge now appears to have been lost on today’s dog owners
    On the surface the idea appears to be highly commendable. With the busy lifestyles we now lead, it would seem feasible to take on two pups. They can stimulate each other and keep themselves company, hopefully alleviating any separation anxiety. They can also imitate the good characteristics of each other. They will be able to do everything together and therefore will benefit from that closeness and companionship, and could glean untold pleasure from each others company.
    Sounds fantastic, unfortunately the reality is far from this ideal, you really get the worst of both worlds in this scenario. The puppies come to rely on each other and it weakens both of them, often to the extent that they become withdrawn from everything other than themselves. I call it “Littermate Syndrome.”
    The puppies can come to fear other dogs, people and any situation where they are separated from each other. The stress this causes can often then spill over into aggression against each other culminating in fighting in some cases causing serious injury or even death, commonly known as “Sibling Rivalry”. Strangely enough the worst fights are normally between bitches.
    Often, we can inadvertently cause the conflict; owners can disturb the hierarchical balance by rushing to protect the would-be subordinate from being “bullied” or “picked on” granting him/her liberties, such as being petted first, which the other dog may consider his due. The lower dog may now feel emboldened enough to challenge the other. “We need to understand that dogs have their own set of social rules, whereas we humans just want democracy.”
    Fighting:
    If you need to break up a fight, squirt the dogs with water or make a loud noise to distract them. Never attempt to break up a dog fight by grabbing the dogs by their collar or getting in between them. Grabbing dogs whilst they are fighting can result in what is called "redirected aggression," where a dog bites you because he thinks you are part of the conflict.
    Sometimes the problem can be resolved if, instead of protecting the underdog the owner supports the hierarchy ie the top dog. Firstly determine who is the more dominant, reinforce that position by feeding, greeting, playing or letting the top dog out first. Usually this will help, but not always. “The problem with that approach is that it’s often difficult to tell who should be the alpha dog, it is also difficult for owners to play favourites with their dogs.
    Two Choices:
    To my mind you have two choices with siblings from the same litter, Whilst I believe the first solution is the most practicable, which is to re-home one of them, I am also aware it is the hardest and most difficult for the owners. If not they will always be damaged by their almost total reliance on each other.
    If you decide to choose this alternative, you can home one of the dogs with another family member or a trusted friend. You will see dramatic improvements to the personalities of both pups. These changes occur almost immediately. Be aware that the longer you delay the harder it will be to part with one of your pups. It is a difficult and agonising decision for someone to make, however in the long run it is in yours and ultimately both your dog’s best interest.
    Your second choice is to create two individual dogs, with two separate identities and personalities, without the total reliance on each other that normally happens in these situations. To do this you will need to work twice as hard because all the things you did together you will now need to do totally apart.
    Things you must do:
    Everything must now be done independently to allow for the Siblings to have any chance of becoming separate entities instead of the reduced sum of the whole.
    • Walk them separately
    • Feed them separately
    • Train them separately
    • Crate them separately
    • Play with them separately
    Literally everything you do should be separate. That includes Puppy and Training classes, take them to a trainer that understands the inherent difficulties of raising two puppies together. Take them on separate nights hopefully to the same trainer. They can play together but only at strict designated times and for a period of no more than 15 minutes each designated play time.
    This regime will not be for life as the pups will, after a period of about 12 to 14 months have formed their own personalities and temperaments; at this age they will have become confident of their own individual abilities. Not as in most cases total inter-dependence to each other when siblings are raised, trained, and fed together.
    Without the total reliance on their sibling for constant support they will grow and blossom into much rounder and less aggressive and fearful individuals. I cannot stress how important it is to separate the siblings until they are older. It will produce two individuals rather than an impaired two parts of the whole.
    It is worth stating that it is not only siblings that have these problems. If you raise two young pups from different litters or even breeds, you can have similar problems. I always recommend my clients to wait till their puppy is 14 months old before purchasing another puppy this then allows you to concentrate all your efforts on that individual and hopefully it will take on some of the good traits of the older more experienced dog.
    I think what truly annoys me are the breeders that sell siblings, and in some cases actually use emotional blackmail to push two pups, For instance " what a shame you can't take two as I may have problems as he's so small/white/little/runt etc and I'll probably have to have him put down in the end". I have no respect for a breeder that uses these tactics or that sell litter mates to one owner. If they are experienced and not a first time breeder then they are well aware of the pitfalls of these actions, and that the dogs will suffer for the rest of their lives.
    I fully agree with that last paragraph! Most pet homes are not aware of the challenges or the huge amount of extra work.
    Nov 2005
    Chicago burbs
    I've never sold more than one at a time. Many people have problems with paying for one dog these days.
