First coat.
Janice
The time has come for me to get Reuben his first coat. awww!!
The days are chilly and he is rather thin/slim and has not got thick curly hair.
I'd idealy like a Barber type waterproof one that has a lining for cold days but havent actually seen one.
What is puzzling me is; can they wear a harness while a coat is on? I see some coats have a hole for the lead to come through, but wouldn't this defeat the object as rain will go through the hole?
Very little rain actually gets through the hole, so don't worry about that.
Some of us put the harness over the top of hte coat - have harnesses in two different sizes, for coats that do not have a hole.
I've had lovely leads from these people that lasted years - they're now doing coats, but the details are not on the website. Worth contacting them though.
Norfolk Hunter Coats are made from Teflon treated cotton in a very fashionable beige check[FONT=Arial, Helvetica, sans-serif].[/FONT]
http://www.dragon-manufacturing.com/index.htm
These look really good too
http://www.annrees.co.uk/dogs/coats/waterproof_dog_coats.htm
Just looking at the link for the dog coats Nicki. Does abybody know the difference between the two shapes? Square and hound? Each size comes in square or hound shape :?
