Results 1 to 10 of 15
Thread: anal glands, again, again...
    Jun 2009
    denmark
    Default anal glands, again, again...
    yesterday i had to take frida to the vet again. one og her anal glands was very big and tender, no abcsess, though.
    usually i empty the anal glands if i find them very full, but with this one i could do nothing. it was so swollen and frida protested at having me thouch it so i thought an abscess might be forming.
    the vet said that the secretion was very hard, very dry, and so vey difficult to squeeze out. she is sure that this gland can't be emtied in the usual manner.
    does anybody have advice for me, if there is anything i can do/feed frida, to make this secretion more fluid?
    i have not encountered this problem before, have no idea if anything can be done.
    Dec 2007
    It's fairly common for Cavaliers to have one side that fills up more quickly than the other. If I were you, I would just empty that side more frequently, maybe once a fortnight or weekly if you think it is required.
    Elspeth
    Jun 2009
    denmark
    thank you for your answer, elspeth. i appreciate
    but the problem is that the fluid is not sufficiently fluid, so it is very, very difficult to get out.
    i was thinking if there is something i could give frida to make it more fluid.
    Prenton Cheshire
    It does no harm to empty them that often if needed ,as my Rosie sometimes even scoots upon return from the vets .And I wont ever contemplate removal.
    Brian M
    Dec 2007
    I have some who produce more solid stuff than others, so I do them more often, and have found that what I get out is more easily removed - even more fluidy because it has not had time to solidify.
    One of the tricks I have used in the past is to soak on old face-flannel in water as hot as your hands can stand comfortably -not scalding, obviously - wring it out (a hot compress)then press it to the anus. You may have to repeat this a few times. It opens up the aperture in the glands and the heat relaxes the whole area, making the process of emptying easier and less painful. Work the gland from underneath, a little pressure at a time in an upward direction toward the tail base. That is less painful.
    It works for impacted milk glands too - the milk justs flows! Worth a try.
    Elspeth
    Jul 2008
    Ireland
    I was just about to advise this ^^
    A hot cloth put up against the dogs bum and left to cool, maybe repeat few times to make sure, is a great way to get things moving back there. Also, if they have a sore gland it helps relieve the pressure a bit.
    Dec 2007
    Great minds.......................well, maybe not, in my case! LOL!
    Elspeth
    Dec 2009
    Nova Scotia, Canada
    In my holistic vet book it says they should NEVER be emptied and that if there is a problem then there is a problem with diet or your dogs living terraine (system). Any thought on this? I have never had any of my dogs in the past done and had no problems (mixed breeds - rescue dogs). Are Cavaliers more prone to this?
    Marjorie
    "when a dog runs at you, whistle for him"
    Henry David Thoreau
    Oct 2008
    Worcestershire, UK
    Many years ago I was advised to switch to Burns Dog Food, which claims to help with anal gland problems. I've never had a Cavalier which did NOT need glands emptying, but these days I don't seem to live at the vet anywhere near so much as I used to, so I'm sticking with Burns.
    Don't know how you folk manage to do the deed yourselves - I tried once, but never again (and I think the Cav in question is still heartily thankful that I leave it to the experts now!)
    Marie-Anne taken over by
    Hattie (Blenheim) Poppy (Blenheim) + Lucy (Shih-tzu)
    Louie, Joss, Peppa, Megan, Victoria all waiting patiently at the Bridge
    Dec 2007
    Quote Originally Posted by Marjorie View Post
    I would say "Yes" Marjorie, and I know my Vet would agree. 2 of my oldies(fatsos) are on Burns and I do think it makes a diffeence to how often they need to be emptied, but it also tends to make them a bit constipated, so.........?.
    Elspeth
