Research: Splitting the dura: alternative surgery
Administrator
Staff member
This is quite interesting:
http://conquerchiari.org/subs only/Volume 7/Issue 7(5)/Dura splitting 7(5).asp
And perhaps would be of relevance to decompressions in cavaliers. Rather than entirely cutting through the dura, the stiff band of tissue that encircles the brain, the surgical team peeled back the first layer -- and had results comparable to more invasive decompressions. As the formation of scar tissue often causes the complications with regular decompressions, and this method seems to stop scar tissue formation, prhaps ths would be a good compromise.
Presumably this is because by lowering the thickness of the dura it becomes more flexible and can adjust to accommodate the brain? Could have promising possibilities for Cavaliers, since I gather scar tissue is a major cause of eventual failure with decompression surgery?
Yes that is what I understand... dog CM/SM can be different because they carry their head horizontally on their necks so maybe it would not work or maybe it would. I believe Geoff Skerritt does decompression something along these lines - he either splits the dura or doesn't remove it, not sure which. I know many of the neurologists/neurosurgeons doing decompressions feel it is important to remove the dura -- we so badly need some comparison studies in dogs!!
That's really interesting Karlin - I think we will all still be learning and experimenting for many years to come...
It would make sense with regard to the scar tissue.
