16th August 2010, 07:27 PM
#1
Horrible grass seeds
Took Barney out today and he started limping, we had a look and thought he had a thorn in his paw, but when I pulled it out it was a grass seed, it's left a little hole. Does he need anything putting on it or best left alone, he is still limping, it was quite a way in? Obviously if he is no better in the morning, I will take him to the vet.
16th August 2010, 07:33 PM
#2
It might be worth bathing his paw in warm water with a bit of disinfectant in it, just to make sure it doesn't get infected until the puncture has closed up. I just use a margarine carton, hold the paw in it for a few minutes and then dry it. He'll probably be OK after a night's rest, at the moment it's just sore to walk on.
16th August 2010, 08:57 PM
#3
He is walking better now.
What kind of disinfectant can you use, do you mean a one specially for animals? We don't have any disinfectant at all.
16th August 2010, 09:58 PM
#4
Not sure what disinfectant you could use - if that happened to one of mine I think I would bathe the area with cooled boiled water with salt added....Hope that helps!!
Grass seeds are a pain in the bum!!
16th August 2010, 11:42 PM
#5
I would use a mild disinfectant like TCP, diluted, but as Teresa says, salt does as well - just to make sure the foot stays clean.
17th August 2010, 01:30 PM
#6
Yes, thanks, salt water is a good healer.
Barney is fine today, back to his normal self.
- You may not post replies
- You may not edit your posts
Forum Rules
