Results 1 to 10 of 13
Thread: 25% of cavaliers with SM symptoms have CM only, not SM
    Exclamation 25% of cavaliers with SM symptoms have CM only, not SM
    That's according to a research sample of clinically affected, scanned cavaliers in the new research paper out from Clare Rusbridge et al. This is the same one Rod notes in an earlier thread about 76% of these dogs also had further syrinxes lower than the C5 vertebrae (and thus dogs with syrinxes are likely to be worse than a mini scan will show).
    Abstract below, but this excerpt from the paper interested me as it suggests a hitherto unexpectedly large number of dogs with clinical signs of SM (all dogs in the study had clinical signs)-- one in four!!! -- have CM only -- which suggests people with such dogs really need to be treating it AS WITH SM, not attributing the problem to some other likely cause (something vets also need to recognise):
    The median age of the dogs included in the study was 5 years (1.2–10.8 years). CM was present in all patients. None of the dogs showed compressive craniocervical pathology other than CM. There was no evidence of SM on MRI in 12/49 (25%) dogs. In all dogs with MRI evidence of SM (37/49; 75%), SM was present within the C1–C4 region (Figs. 2 and 3). Of those dogs with SM within C1– C4 region, 76% (28/37) also had SM within the C5–T1 and/ or T2–L2 regions, but only 49% (18/37) had SM within the L3–L7 region.
    Abstract
    Chiari-like malformation (CM) and syringomyelia (SM) is an important disease complex in the Cavalier King Charles Spaniel (CKCS) but data about the anatomical distribution of SM along the spinal cord are lacking in veterinary medicine. The objective of this study was to define the anatomic distribution of SM in CKCS clinically affected by CM/SM. Magnetic resonance imaging (MRI) of the brain and the entire spinal cord of 49 dogs was performed and different morphological parameters compared.
    Syrinx formation was present in the C1–C4 region and in other parts of the spinal cord. The maximal dorsoventral syrinx size can occur in any region of the spinal cord and the total syrinx size was positively correlated with age. Seventy-six per cent of CKCS with a cranial cervical syrinx also have a syrinx affect- ing more caudal spinal cord regions. MRI restricted to the cervical region may underestimate the extent of SM and the severity of the disease process in the majority of dogs.
    May 2006
    Orlando, Florida USA
    Quote Originally Posted by Karlin View Post
    The researchers in that article go on to explain about the pain sensations experienced by the dogs having only CM:
    Dogs with CM without SM can experience discomfort and pain possibly due to a direct compression of the medulla oblongata, which is involved in modulation of pain and projects to trigeminal nuclei and spinal cord dorsal horn (Rusbridge and Jeffery, 2006; Taylor and Larkins, 2002).
    One other item in the article, which I found to be interesting, is this:
    ... measurements of the syrinx in T2-weighted images may result in an overestimation of the syrinx size as they include the hyperintense signal associated with interstitial oedema. In the majority of cases in our study, the syrinx borders were not well demarcated on T2-weighted MR images. Syrinx outlines were however distinctly visible in T1-weighted images. In view of these findings and the reported literature, T1-weighted images were used for all measurements in our study.
    Rod Russell
    Jun 2010
    Charlotte, North Carolina, United States
    Can someone explain in simple terms some things.
    1) I have read that as much as 95% of ckcs have CM (correct me but this seems on the higher side and I am not sure where I saw that sorry). With these results along with people on forum and others I have talked to have said that their cavaliers have symptoms pain with CM alone, do we know why some have more "severe" or symptamatic?
    2) karlin, you bring up a good point about them both being treated the same meaning with medication etc. It seems like SM/CM either one can be painful or not (depending). You could argue that a CM (no SM) with symptoms compared to an asymptomatic SM cavalier would bring up a whole other can of worms. Just because they do not have SM, doesn't mean they are better off especially if they have pain.
    3) in other breeds, someone mentioned that they can have SM without CM. Is that pretty much just other breeds? Maybe the only time you would see in a cavalier is if it was caused by an accident?
    4) do we know why some develop symptoms and others not? Especially since there is a larger % of cavaliers with CM?
    I guess that's it for now.. sorry for the questions but seems with research you find information that brings up other questions.
    Sent from my Droid using Tapatalk
    Anne Proud mother of Elton 5 and Angel Ella
    May 2006
    Quote Originally Posted by anniemac View Post
    Enough, already! You're making my head hurt!
    Yes, some researchers have estimated that as many as 95% of cavaliers may have Chiari-like malformation (CM). That is based upon statistics among CKCSs examined during the researchers' studies. If that percentage is close to accurate, then it may also be said that CM is "normal" for the breed, meaning that so many have it, that not to have it is abnormal.
    It is like the Dalmatian. 100% of Dalmatians registered with the American Kennel Club (AKC) have a malformed version of the SLC2A9 gene, which causes excessively high levels of uric acid, and in up to a third of all males, also creates painful urate stones which can cause blockages and which may require repeated surgeries to remove. In the AKC version of the Dalamatian, the malformed SLC2A9 gene is "normal".
    It's like in an insane asylum, crazy is normal.
    Back to the article being discussed: As the researchers have explained, "Dogs with CM without SM can experience discomfort and pain possibly due to a direct compression of the medulla oblongata, which is involved in modulation of pain and projects to trigeminal nuclei and spinal cord dorsal horn."
    I don't think they yet know why some dogs have pain from CM and others do not. Perhaps it is the severity of the CM, combined with the level of the threshold of pain in the particular dog. It is difficult to objectively measure the level of pain in a dog.
    But the fact that (a) CM alone can cause severe pain, coupled with the other fact that (b) a large majority of cavaliers -- maybe not 95% but a high number nonetheless -- have CM, can amount to this scary proposition: (c) That CM is normal in the breed, and pain is, perhaps, normal for CM, so therefore, pain is normal in the breed.
    As it is with the Dalamatian: high levels of uric acid are normal, causing painful stones in a third of the males. So it may be with the cavalier: nearly all have CM, which alone can cause severe pain. We just don't yet know what the percentage of cavaliers with painful CM is yet.
    Yes, in other breeds, including the Griffon, syringomyelia (SM) may appear without CM. In the cavalier, absent a trauma or other environmental influences, SM exists only if CM exists.
    A corrollary to your question about CM is: Why do some cavaliers with SM have symptoms and others do not? That has been a topic of studies. In a 2007 report ( http://www.cavalierhealth.org/syring...ia_in_cavalier ), the researchers wrote: "Maximum syrinx width was the strongest predictor of pain, scratching behaviour and scoliosis in dogs with syringomyelia. Both pain and syrinx size were positively correlated with syrinxes located in the dorsal half of the spinal cord."
    Also, in a 2010 study ( http://www.cavalierhealth.org/syring...ked_Potentials ) the researchers reported: "A significant linear correlation was observed between the severity of neurologic dysfunction and size of the syrinx, with a larger syrinx being associated with more severe neurologic signs."
    Since SM is progressive, it may be that for cavaliers with SM but no pain, it is just a matter of time. Much like dying from congestive heart failure due to MVD is just a matter of time for many cavaliers with incipient murmurs.
    Rod Russell
    Jun 2010
    Rod, I'm going to FL tomorrow. Don't you live in Tallahassee? Why don't I stop by and I can ask you questions for a couple hours? I bet that sounds fun
    North Scotland - east coast
    Thank you for posting this Karlin - it's very scary, particularly as breeders are making decisions based on the absence of presence of syrinxes...
    What a truly awful thought that pain might be the NORMAL condition for the Cavalier
    Annie, you raise good questions and we are lucky to have some very informed members to answer them
    Firstly this incidence is truly shocking [although relates to my personal experience - I thought perhaps we had just been unlucky]
    from http://sm.cavaliertalk.com/
    Typical symptoms may include only ONE, or SEVERAL, of these signs:
    • excessive scratching, especially at ears, head, face, neck, shoulders (only some SM dogs scratch!)
    • 'air scratching' (the hind leg makes no body contact, typically when walking the dog)
    • scoliosis (especially in young dogs), where the dog's neck and spine bend into a 'C'
    • weakness in the legs
    • pain, especially around the head, spine and/or legs
    • sudden yelping for no reason
    • flipping around to bite at the hindquarters
    CM/SM is often misdiagnosed by vets as:
    • allergies
    • ear problems
    • spinal/disk problems
    CM - treating it AS WITH SM
    treatment options here
    http://sm.cavaliertalk.com/treating/treatingsm.html
    May 2006
    Thank goodness, I'm many hours away from Tallahassee! ;<)
    Rod Russell
    Jun 2010
    [QUOTE=RodRussell;377913]Thank goodness, I'm many hours away from Tallahassee! ;
    Jun 2007
    Hatfield, Herts, UK
    Quote Originally Posted by Nicki View Post
    I feel totally depressed at that thought, because I believe it may well soon be the truth.
    I really struggle with the question as to whether the incidence of both CM and SM is rapidly getting worse, or whether awareness of the condition has made owners more aware of 'quirky' behaviour that would not have been recognised as pain symptoms in the past.
    Although I know I have owned cavaliers in the past that on hindsight showed mild symptoms, I do not believe that the extent of suffering in young dogs that we are seeing now would have gone unnoticed. I worry we are at the start of an explosion of dogs showing up with pain caused by CM and/or SM.
    I have a scanned dog staying with me who has CM, no SM, but his symptoms are obvious and he has been prescribed painkilling medication.
    Grooming him leaves him scratching uncontrollably however gentle I try to be.
    Margaret C
    Cavaliers......Faith, The Ginger Tank and Woody.
    Japanese Chins.... Dandy, Benny, Bridgette and Hana.
    Remembered with love......... Tommy Tuppence and Fonzi
Tags for this Thread
