Blondiemonster
i got a callback from Dr. Marino. He says in his experience the tubes don't work very well in dogs. I think he said he used to do it, but Im not a hundred percent sure. (regardless, the info from the Dr. at Ohio state that it has never been done in the States doesn't seem accurate, since Marino defenitely has experience with it)
Anyhow, he says the draining as opposed to the tubes is way more succesful, and he said that LIVS has had the highest succesrate with their draining of PSOM so far. I think, it's based on the (unpublished) study they are conducting on it.
Now here is the good news;
PSOM after the first draining only comes back in 30 percent of all dogs a second time. (we were amongst the unlucky ones..) Only about half of the second cases gets it again a thirds time, and so far, he hasn't seen a case needing a 4th time.
Which means , between the draining and antibiotics they give after, there is light at the end of the tunnel. Or so it seems.
