cyst growing on her side
Nalu
Should I have a cyst growing on the side of a 13 mo cavie removed? Is it cause for alarm?
Benign cysts can form, and will often cause no trouble, but it's important that you see your vet about this for a biopsy. There is no way for us to tell you whether or not a bump is cancerous.
As Soushiruiuma says, you should consult with your vet about this. Many cysts are completely harmless and veterinary advice is often just to leave them alone, but only a professional can tell the difference between such a cyst and anything that needs more attention.
Good luck - let us know how you get on.
