Does he have a visible waistline? 25 lbs. is a whole lot for the breed in general. Read about body condition scoring here:
http://www.cavalierhealth.org/diets....dition_Scoring
Thank you for the link. Since I am not good at measuring the waistline visually, I tried to go over his entire body with my hands. I feel he is at the "Moderate" stage because I can feel his ribs very easily without "excess fat cover" as well as "Abdomen tucked up when viewed from side." Right now, his chest has bulged a bit to accommodate his enlarged heart.
Some drugs have been known, in some cases, to reduce the size of enlarged hearts. There is a discussion of the drugs regularly prescribed for cavaliers with MVD at
http://www.cavalierhealth.org/mitral...tm#--_moderate
Does he have fluid in his lungs? I did not see that you mentioned that in your list of what the cardiologist found. If he does have fluid in the lungs, there are drugs for that, but this condition usually does not arise until the dog reaches the end stage of congestive heart failure. This is from
http://www.cavalierhealth.org/mitral...se.htm#--_end:
Yes, you are right on here. I misspoke on this. As I go over the report by the cardiologist again, I only find the "... mechanical compression of bronchi from LA enlargement" regarding the cough. Somehow in my head, fluid and coughing had been tightly interwoven. I need to untangle it. Thank you.
"Dogs with severe flooding of the lungs should not be exerted in any way. Some cardiologists may prescribe a bronchial dialator, such as aminophylline, oxtriphylline, or theophylline (Corvental), which are human grade prescription medications which relax and open air passages in the lungs, making breathing easier. The onset of acute pulmonary edema requires immediate recognition and therapy, including oxygen treatment, in order to save the dog's life. (See the Darcy's Daily Blog entry dated 8/25/06 for details of symptoms requiring oxygen treatment.) Retained fluids (ascites), which fill the peritoneal cavity of the abdomen due to tricuspid valve deterioration, may be removed periodically by aspiration with a hypodermic needle (abdominocentesis)."
Thank you for the info. Karlin also noted on this point. I need to moderate his walking and be thoughtful.
I would follow the advice of the cardiologist. Also, as Karlin suggested, read
http://www.cavalierhealth.org/images...ccvhd_2009.pdf Start on page 1145 under the section that is titled "Stage B2, and limit your reading to "small breed dogs".
As as a matter of fact, when I was reading through the paper this morning, I felt he was at the stage of B2 and I read that section carefully.
I must have missed something. In what instances has the cardiologist been non-responsive? Once our cavaliers reach the stage of MVD where yours is, we deal directly with the cardiologist. We schedule either annual or semi-annual visits with the cardiologist. The cardiologist does the prescribing. Your dog is at the stage where he needs a hands-on relationship with the cardiologist.
