Thread: Advice about a harness
    Jan 2013
    Default Advice about a harness
    Hi everyone, new to this forum. I have a one year old tri-colour who loves to go out running. The problem is finding a suitable harness that does not cause friction against his skin ultimately leaving him with sores poor wee thing. He is now out of action until he heals and we can find a suitable harness. We have tried 2 different types but they have caused - first one rubbing against his leg and second one which was padded causing damage and swelling in his armpits. He is really missing going out and is sulking lol If anyone can suggest anything they have used as I do not want to put him through trial and error (may cause more pain) if someone can suggest one. Thank you
    New Orleans
    It sounds like the harnesses aren't adjusted to him. You shouldn't be having these kinds of problems with any harness.
    Is he a puller? That would make pressure points worse. Try to find a qualified trainer in your area, I forget the certifying agencies but they've been listed in numerous puppy and training posts.
    I prefer the Easy-walk harness for a puller but if you're having trouble with friction that one is a thin nylon harness so it may not be the best.
    The Puppia harnesses are made of a soft mesh material that, I think, would cause the least amount of friction due to the bigger surface area and soft fabric - but as a back-clip are not good for a dog that pulls.
    But like Soushiruiuma says, this doesn't sound like a normal issue though - there may be some underlying problems.
    Courtney
    Lady (1 year old tricolour) & Gracie (3 year old blenheim)
    I agree about fit or something but....I started out using the Puppia ones I think the surface area mesh thing helps. Fletcher is a puller and I use an EZ walk and hw still pulls!!!! My crazy little dog does not seem to understand why his harness its so comfortible when he pulls and I stop...........if he could talk, I think he'd say "what happened" everytime
    I suggest you either try finding a local pet shop hopefully with a person who can help you find a harness to fit right or maybe a training club for advice.
    Jan 2013
    He is a puller on a collar but he is ok on a harness. The harnesses are fine and cause no problem if he is out normal walking but he likes to accompany me when I'm out running and this is when the problem starts. The harnesses have been to my knowledge fitted correctly. I have taken him over to the local shop on both occasions to ensure a proper fitting harness which cause no problems when walking only when he is out long distance running. Does the EZ walk harness stay at the belly or does it travel down to the armpit area?? lol It took me an hour to work out how to reply before I noticed I wasn't logged in haha
    Oh -- I thought the question was about running when playing but now see it is for actually *running*. In this case, before I suggest a harness, I'd note a serious caveat: cavaliers because they are flatter-faced can easily overheat and get seriously ill if out running any distance. Generally a cavalier would not really be a running companion breed and I'd be concerned if he was running anything over perhaps a mile if even that nonstop. Generally a dog will not indicate to its owner that it is getting distressed if out running; it will just keep going. There are also serious questions of joint damage with younger dogs (eg before growth plates close which usually happens around a year and a half -- puppies younger than that should never be out jogging for long distances.
    Most harnesses will chafe if used for a running dog -- many brands state the harnesses should be removed for play and activity as they are really intended for walking. There is one type that is designed to avoid this -- I note vet Dr Sophia Yin has mentioned it on her blog before; it's the harness she recommends. Maybe this would work for you? I'll see if I can find it. But I'd really be cautious about jogging any distance with a cavalier -- they are well able for active walks or for agility for example but brachycephalic (flat and flatter-faced) dogs are generally not advised as dogs to be ever used as running friends, I'm afraid.
    On running with dogs:
    This is from the ASPCA website and is also on the WebMD pet section: http://www.aspca.org/Pet-care/virtua...cise-for-dogs:
    Before You Start Your Dog’s Exercise Program
    Check with your dog’s veterinarian before starting an exercise program. He or she can check your dog for any health issues that may be aggravated by exercise and suggest safe activities. Some size, breed and age considerations are:
    *Breeds with short or flat noses (brachycephalic breeds) can have trouble breathing when exercised vigorously, especially in warmer climates.
    *Exercise is great for energetic young dogs, but sustained jogging or running is not recommended for young dogs (under 18 months) whose bones haven’t finished growing.
    And this article from a dog trainer, on whether it is safe to jog with a dog (cavaliers are both a toy breed and brachycephalic): http://www.dogtrainingblogger.com/is...th-my-dog.html
    What breed is your dog? If you have a medium or large sporting breed or one of the medium or large herding, working or hound breeds, then it’s likely that your dog will have no trouble keeping up with you as you jog. Some of these breeds may have a high energy level, such as the Border Collie, while other breeds may have been bred to run, such as the Greyhound and the Whippet. These dogs will probably love going jogging with you. However, if you have a toy dog or a smaller breed, one of the dwarf breeds or a brachycephalic breed (short-muzzled), then jogging is not a good idea.
    Also see this AKC research article on the issue: http://www.akcchf.org/news-events/li...rch-shows.html
    Here you go, about halfway down Dr Yin (vet) discusses some of the "Freedom" and other front clip harnesses that do not hinder movement as much as harnesses intended for walking:
    http://drsophiayin.com/blog/entry/wh...e-for-your-dog
    Jan 2013
    Hi Karlin, thank you very much for your input. Do you know the name of the harness she refers to? He started running when he turned one beginning of January. I consulted with my vet and he feels that Patch is in great condition he does 5 miles 6 days a week and he is doing more of a fast walk than a run although I am running lol He comes back into the house full of energy and ready to play. At the moment the weather here is rather cold but he will not be running in hotter weather although we very rarely see that anyway.
    She names the harnesses and compares them at the link posted. The In-Synch one is the one she seems to most recommend but she compares that and the Freedom on her blog post linked to.
    Hmmm. How familiar is your vet with cavaliers? They are not a really common breed outside the UK/Ireland and maybe vets are sometimes not clear on the breathing obstructions they can have and how serious they can be (see www.cavalierhealth.org) -- or that the breed is classified as brachycephalic. I also can only say the general advice from vets is that dogs should not be doing hard running or agility before 18 months because they are at risk of damaging joints. Most agility classes will not accept dogs before they are 18 months for anything other than gentle fun pre-agility activities (eg little tiny jumps). You can find the 18-month recommendation quite widely on vet advice sites and trainer sites.
    Personally I would never bring a cavalier on a 5-6 mile run. Walk, definitely! We've done 12 miles before. But never a run. Especially not in an area with warm to hot temps in summer. Cockers and Springers are spaniels well able for a long run, by contrast -- they have normal muzzle lengths.
    Jan 2013
    The vet is very familiar with the breed however I will consult another vet to ensure that he is ok to do this. My father has had sporting dogs all his life and this is why we waited until a year old before starting him as a running companion. He is in great condition at the moment no health concerns at all but he is our pride and joy and would not want to do anything to harm him.
